ONC+ Developer's Guide
portmap Operation
portmap currently supports two protocols (UDP/IP and TCP/IP). portmap is contacted by talking to it on assigned port number 111 (SUNRPC (5)) on either of these protocols. The following sections describe each of the port-mapper procedures.
PMAPPROC_NULL
This procedure does no work. By convention, procedure zero of any protocol takes no parameters and returns no results.
PMAPPROC_SET
When a program first becomes available on a machine, it registers itself with the local port map program. The program passes its program number prog, version number vers, transport protocol number prot, and the port port on which it receives service requests. The procedure refuses to establish a mapping if one already exists for the specified port and it is bound. If the mapping exists and the port is not bound, portmap unregisters the port and performs the requested mapping. The PMAPPROC_SET procedure returns TRUE if the procedure successfully established the mapping and FALSE otherwise. See also the pmap_set() function in the rpc_soc(3NSL) man page.
PMAPPROC_UNSET
When a program becomes unavailable, it should unregister itself with the port-mapper program on the same machine. The parameters and results of PMAPPROC_UNSET have meanings identical to those of PMAPPROC_SET. The protocol and port number fields of the argument are ignored. See also the pmap_unset() function in the rpc_soc(3NSL) man page.
PMAPPROC_GETPORT
Given a program number prog, version number vers, and transport protocol number prot, the PMAPPROC_GETPORT procedure returns the port number on which the program is awaiting call requests. A port value of zeroes means the program has not been registered. The port field of the argument is ignored. See also the pmap_getport() function in the rpc_soc(3NSL) man page.
PMAPPROC_DUMP
The PMAPPROC_DUMP procedure enumerates all entries in the port mapper's database. The procedure takes no parameters and returns a list of program, version, protocol, and port values. See also the pmap_getmaps() function in the rpc_soc(3NSL) man page.
PMAPPROC_CALLIT
The PMAPPROC_CALLIT procedure enables a caller to call another remote procedure on the same machine without knowing the remote procedure's port number. It supports broadcasts to arbitrary remote programs by using the well-known port mapper's port. The parameters prog, vers, proc, and the bytes of args are the program number, version number, procedure number, and parameters of the remote procedure. See also the pmap_rmtcall() function in the rpc_soc(3NSL) man page.
This procedure only sends a response if the procedure was successfully executed and is silent (no response) otherwise. It also returns the remote program's port number, and the bytes of results are the results of the remote procedure.
The port mapper communicates with the remote program using UDP/IP only.
