ONC+ Developer's Guide
Per-Service Configuration Scripts
Per-service configuration scripts are interpreted by the port monitor before the service is invoked.
pmadm -g -p pmtag -s svctag [ -z script ]
 pmadm -g -s svctag -t type -z script
Note –
The SAC interprets both its own configuration file, _sysconfig, and the port monitor configuration files. Only the per-service configuration files are interpreted by the port monitors.
The -g option is used to print, install, or replace a per-service configuration script. The -g option with a -p option and a -s option prints the per-service configuration script for service svctag available through port monitor pmtag. The -g option with a -p option, a -s option, and a -z option installs the per-service configuration script contained in the file script as the per-service configuration script for service svctag available through port monitor pmtag. The -g option with a -s option, a -t option, and a -z option installs the file script as the per-service configuration script for service svctag available through any port monitor of type type. Other combinations of options with -g are invalid.
The following per-service configuration script controls two settings: It specifies the maximum file size for files created by a process by setting the process's ulimit to 4096. It also specifies the protection mask to be applied to files created by the process by setting umask to 077.
runwait ulimit 4096
runwait umask 077
