Assume that an application runs on a single computer and you want to convert it to run in a “distributed” manner on a network. This example shows the stepwise conversion of this program that writes a message to the system console. The following code example shows the original program.
/* printmsg.c: print a message on the console */ #include <stdio.h> main(argc, argv) int argc; char *argv[]; { char *message; if (argc != 2) { fprintf(stderr, "usage: %s <message>\n", argv[0]); exit(1); } message = argv[1]; if (!printmessage(message)) { fprintf(stderr,"%s: couldn't print your message\n",argv[0]); exit(1); } printf("Message Delivered!\n"); exit(0); } /* Print a message to the console. * Return a boolean indicating whether * the message was actually printed. */ printmessage(msg) char *msg; { FILE *f; f = fopen("/dev/console", "w"); if (f == (FILE *)NULL) { return (0); } fprintf(f, "%s\n", msg); fclose(f); return(1);}
For local use on a single machine, this program could be compiled and executed as follows:
$ cc printmsg.c -o printmsg $ printmsg "Hello, there." Message delivered! $
If the printmessage() function is turned into a remote procedure, the function can be called from anywhere in the network.
First, determine the data types of all procedure-calling arguments and the resulting argument. The calling argument of printmessage() is a string, and the result is an integer. You can write a protocol specification in the RPC language that describes the remote version of printmessage(). The RPC language source code for such a specification is:
/* msg.x: Remote msg printing protocol */ program MESSAGEPROG { version PRINTMESSAGEVERS { int PRINTMESSAGE(string) = 1; } = 1; } = 0x20000001;
Remote procedures are always declared as part of remote programs. The previous code declares an entire remote program that contains the single procedure PRINTMESSAGE. In this example, the PRINTMESSAGE procedure is declared to be procedure 1, in version 1 of the remote program MESSAGEPROG, with the program number 0x20000001. See Appendix B, RPC Protocol and Language Specification for guidance on choosing program numbers.
Version numbers are incremented when functionality is changed in the remote program. Existing procedures can be changed or new ones can be added. More than one version of a remote program can be defined and a version can have more than one procedure defined.
Note that the program and procedure names are declared with all capital letters.
Note also that the argument type is string
and not char *
as it would be in C. This is because a char *
in
C is ambiguous. char
usually means an array of characters, but
it could also represent a pointer to a single character. In the RPC language,
a null-terminated array of char
is called a string
You have just two more programs to write:
The remote procedure itself
The main client program that calls it
Example 3–2 is a remote procedure that implements the PRINTMESSAGE procedure in Example 3–1.
/* * msg_proc.c: implementation of the * remote procedure "printmessage" */ #include <stdio.h> #include "msg.h" /* msg.h generated by rpcgen */ int * printmessage_1(msg, req) char **msg; struct svc_req *req; /* details of call */ { static int result; /* must be static! */ FILE *f; f = fopen("/dev/console", "w"); if (f == (FILE *)NULL) { result = 0; return (&result); } fprintf(f, "%s\n", *msg); fclose(f); result = 1; return (&result);}
The declaration of the remote procedure printmessage_1() differs from that of the local procedure printmessage() in four ways:
printmessage_1() takes a pointer to the
character array instead of the pointer itself. This principle is true of all
remote procedures when the -N option is not used. These procedures
always take pointers to their arguments rather than the arguments themselves.
Without the -N option, remote procedures are always called
with a single argument. If more than one argument is required the arguments
must be passed in a struct
printmessage_1() is called with two arguments. The second argument contains information on the context of an invocation: the program, version, and procedure numbers; raw and canonical credentials; and an SVCXPRT structure pointer. The SVCXPRT structure contains transport information. All of the information is made available in case the invoked procedure requires it to perform the request.
printmessage_1() returns a pointer to an
integer instead of the integer itself. This principle is also true of remote
return pointers to the result. The result should be declared static
unless the -M (multithread) or -A
(Auto mode) options are used. Ordinarily, if the result is declared local
to the remote procedure, references to the result by the server stub are invalid
after the remote procedure returns. In the case of -M and -A options, a pointer to the result is passed as a third argument
to the procedure, so the result is not declared in the procedure.
An _1 is appended to the printmessage_1() name. In general, all remote procedures calls generated by rpcgen are named as follows: the procedure name in the program definition (here PRINTMESSAGE) is converted to all lowercase letters, an underbar (_) is appended to it, and the version number (here 1) is appended. This naming scheme enables you to have multiple versions of the same procedure.
The following code example shows the main client program that calls the remote procedure.
/* * rprintmsg.c: remote version * of "printmsg.c" */ #include <stdio.h> #include "msg.h" /* msg.h generated by rpcgen */ main(argc, argv) int argc; char *argv[]; { CLIENT *clnt; int *result; char *server; char *message; if (argc != 3) { fprintf(stderr, "usage: %s host message\n", argv[0]); exit(1); } server = argv[1]; message = argv[2]; /* * Create client "handle" used for * calling MESSAGEPROG on the server * designated on the command line. */ clnt = clnt_create(server, MESSAGEPROG, PRINTMESSAGEVERS, "visible"); if (clnt == (CLIENT *)NULL) { /* * Couldn't establish connection * with server. * Print error message and die. */ clnt_pcreateerror(server); exit(1); } /* * Call the remote procedure * "printmessage" on the server */ result = printmessage_1(&message, clnt); if (result == (int *)NULL) { /* * An error occurred while calling * the server. * Print error message and die. */ clnt_perror(clnt, server); exit(1); } /* Okay, we successfully called * the remote procedure. */ if (*result == 0) { /* * Server was unable to print * our message. * Print error message and die. */ fprintf(stderr, "%s: could not print your message\n",argv[0]); exit(1); } /* The message got printed on the * server's console */ printf("Message delivered to %s\n", server); clnt_destroy( clnt ); exit(0);}
In the example code, a client handle is created by the RPC library routine clnt_create(). This client handle is passed to the stub routine that calls the remote procedure. See Chapter 4, Programmer's Interface to RPC for details on how the client handle can be created in other ways. If no more calls are to be made using the client handle, destroy it with a call to clnt_destroy() to conserve system resources.
The last parameter to clnt_create() is visible, which specifies that any transport noted as visible in /etc/netconfig can be used. For further information on transports, see the /etc/netconfig file and its description in Programming Interfaces Guide.
The remote procedure printmessage_1() is called exactly the same way as it is declared in msg_proc.c, except for the inserted client handle as the second argument. The remote procedure also returns a pointer to the result instead of the result.
The remote procedure call can fail in two ways. The RPC mechanism can fail or an error can occur in the execution of the remote procedure. In the former case, the remote procedure printmessage_1() returns a NULL. In the latter case, the error reporting is application dependent. Here, the error is returned through *result.
The compile commands for the printmsg example are:
$ rpcgen msg.x $ cc rprintmsg.c msg_clnt.c -o rprintmsg -lnsl $ cc msg_proc.c msg_svc.c -o msg_server -lnsl
rpcgen is used to generate the header files (msg.h), client stub (msg_clnt.c), and server stub (msg_svc.c). Then, two programs are compiled: the client program rprintmsg and the server program msg_server. The C object files must be linked with the library libnsl, which contains all of the networking functions, including those for RPC and XDR.
In this example, no XDR routines were generated because the application uses only the basic types that are included in libnsl.
rpcgen received the input file msg.x and created:
A header file called msg.h that contained #define statements for MESSAGEPROG, MESSAGEVERS, and PRINTMESSAGE for use in the other modules. This file must be included by both the client and server modules.
The client stub routines in the msg_clnt.c file. Only one routine, the printmessage_1() routine, was called from the rprintmsg client program. If the name of an rpcgen input file is FOO.x, the client stub's output file is called FOO_clnt.c.
The server program in msg_svc.c that calls printmessage_1() from msg_proc.c. The rule for naming the server output file is similar to that of the client: for an input file called FOO.x, the output server file is named FOO_svc.c.
After the server program is created, it is installed on a remote machine and run. If the machines are homogeneous, the server binary can just be copied. If they are not homogeneous, the server source files must be copied to and compiled on the remote machine. For this example, the remote machine is called remote and the local machine is called local. The server is started from the shell on the remote system:
remote$ msg_server
Server processes generated with rpcgen always run in the background. You do not have to follow the server's invocation with an ampersand (&). Servers generated by rpcgen can also be invoked by port monitors like listen() and inetd(), instead of from the command line.
Thereafter, a user on local can print a message on the console of machine remote as follows:
local$ rprintmsg remote "Hello, there."
Using rprintmsg, a user can print a message on any system console, including the local console, when the server msg_server is running on the target system.
