ONC+ Developer's Guide
Top-Level Interface
At the top level, the application can specify the type of transport to use but not the specific transport. This level differs from the simplified interface in that the application creates its own transport handles in both the client and server.
Client Side of the Top-Level Interface
Assume the header file in the following code example.
Example 4–7 time_prot.h Header File
/* time_prot.h */
#include <rpc/rpc.h>
#include <rpc/types.h>
struct timev {
	int second;
	int minute;
	int hour;
typedef struct timev timev;
bool_t xdr_timev();
#define TIME_PROG 0x40000001
#define TIME_VERS 1
#define TIME_GET  1
The following example shows the client side of a trivial date service using top-level service routines. The transport type is specified as an invocation argument of the program.
Example 4–8 Client for Trivial Date Service
#include <stdio.h>
#include "time_prot.h"
#define TOTAL (30)
 * Caller of trivial date service
 * usage: calltime hostname
main(argc, argv)
	int argc;
	char *argv[];
	struct timeval time_out;
	CLIENT *client;
	enum clnt_stat stat;
	struct timev timev;
	char *nettype;
	if (argc != 2 && argc != 3) {
		fprintf(stderr,”usage:%s host[nettype]\n”
	if (argc == 2)
		nettype = "netpath";		/* Default */
		nettype = argv[2];
	client = clnt_create(argv[1], TIME_PROG,
									TIME_VERS, nettype);
	if (client == (CLIENT *) NULL) {
		clnt_pcreateerror(“Couldn't create client”);
	time_out.tv_sec = TOTAL;
	time_out.tv_usec = 0;
	stat = clnt_call( client, TIME_GET,
					xdr_void, (caddr_t)NULL,
					xdr_timev, (caddr_t)&timev,
	if (stat != RPC_SUCCESS) {
		clnt_perror(client, "Call failed");
	fprintf(stderr,"%s: %02d:%02d:%02d GMT\n",
				nettype timev.hour, timev.minute,
	(void) clnt_destroy(client);
If nettype is not specified in the invocation of the program, the string netpath is substituted. When RPC libraries routines encounter this string, the value of the NETPATH environment variable governs transport selection.
If the client handle cannot be created, display the reason for the failure with clnt_pcreateerror(). You can also get the error status by reading the contents of the global variable rpc_createerr.
After the client handle is created, clnt_call() is used to make the remote call. Its arguments are the remote procedure number, an XDR filter for the input argument, the argument pointer, an XDR filter for the result, the result pointer, and the time-out period of the call. The program has no arguments, so xdr_void() is specified. Clean up by calling clnt_destroy().
To bound the time allowed for client handle creation in the previous example to 30 seconds, replace the call to clnt_create() with a call to clnt_create_timed() as shown in the following code segment:
 struct timeval timeout;
 timeout.tv_sec = 30;		/* 30 seconds */
 timeout.tv_usec = 0;
 client = clnt_create_timed(argv[1],
					TIME_PROG, TIME_VERS, nettype,
The following example shows a top-level implementation of a server for the trivial date service.
Example 4–9 Server for Trivial Date Service
#include <stdio.h>
static void time_prog();
	int argc;
	char *argv[];
	int transpnum;
	char *nettype;
	if (argc > 2) {
		fprintf(stderr, "usage: %s [nettype]\n",
	if (argc == 2)
		nettype = argv[1];
	transpnum =
	if (transpnum == 0) {
		fprintf(stderr,”%s: cannot create %s service.\n”,
					argv[0], nettype);
 * The server dispatch function
static void
time_prog(rqstp, transp)
	struct svc_req *rqstp;
	SVCXPRT *transp;
	struct timev rslt;
	time_t thetime;
	switch(rqstp->rq_proc) {
		case NULLPROC:
			svc_sendreply(transp, xdr_void, NULL);
		case TIME_GET:
	thetime = time((time_t *) 0);
	rslt.second = thetime % 60;
	thetime /= 60;
	rslt.minute = thetime % 60;
	thetime /= 60;
	rslt.hour = thetime % 24;
	if (!svc_sendreply( transp, xdr_timev, &rslt)) {
svc_create() returns the number of transports on which it created server handles. time_prog() is the service function called by svc_run() when a request specifies its program and version numbers. The server returns the results to the client through svc_sendreply().
When you use rpcgen to generate the dispatch function, svc_sendreply() is called after the procedure returns. Therefore, rslt in this example must be declared static in the actual procedure. svc_sendreply() is called from inside the dispatch function, so rslt is not declared static.
In this example, the remote procedure takes no arguments. When arguments must be passed, the calls listed below fetch, deserialize (XDR decode), and free the arguments.
svc_getargs( SVCXPRT_handle, XDR_filter, argument_pointer);
svc_freeargs( SVCXPRT_handle, XDR_filter argument_pointer );
