ONC+ Developer's Guide
DES Authentication Protocol (in XDR language)
Credentials are explained in the following example:
Example B–2 AUTH_DES Authentication Protocol
 * There are two kinds of credentials: one in which the client
 * uses its full network name, and one in which it uses its
 * “nickname” (just an unsigned integer) given to it by the
 * server. The client must use its full name in its first
 * transaction with the server, in which the server returns
 * to the client its nickname. The client may use its nickname
 * in all further transactions with the server. There is no
 * requirement to use the nickname, but it is wise to use it for
 * performance reasons.
enum authdes_namekind {
 * A 64-bit block of encrypted DES data
 typedef opaque des_block[8];
 * Maximum length of a network user's name
const MAXNETNAMELEN = 255;
 * A fullname contains the network name of the client, an
 * encrypted conversation key and the window. The window
 * is actually a lifetime for the credential. If the time
 * indicated in the verifier timestamp plus the window has
 * passed, then the server should expire the request and
 * not grant it. To insure that requests are not replayed,
 * the server should insist that timestamps be greater
 * than the previous one seen, unless it is the first transaction.
 * In the first transaction, the server checks instead that the
 * window verifier is one less than the window.
struct authdes_fullname {
 	string name<MAXNETNAMELEN>; /* name of client */
 	des_block key;              /* PK encrypted conversation key */
 	unsigned int window;        /* encrypted window */
};                             /* NOTE: PK means "public key" */
 * A credential is either a fullname or a nickname
 		authdes_fullname adc_fullname;
 		unsigned int adc_nickname;
 * A timestamp encodes the time since midnight, January 1, 1970.
struct timestamp {
 	unsigned int seconds;      /* seconds */
 	unsigned int useconds;     /* and microseconds */
 * Verifier: client variety
struct authdes_verf_clnt {
 	timestamp adv_timestamp;   /* encrypted timestamp */
 	unsigned int adv_winverf;  /* encrypted window verifier */
 * Verifier: server variety
 * The server returns (encrypted) the same timestamp the client gave
 * it minus one second. It also tells the client its nickname to be
 * used in future transactions (unencrypted).
struct authdes_verf_svr {
 	timestamp adv_timeverf;    /* encrypted verifier */
 	unsigned int adv_nickname; /* new nickname for clnt */};
Diffie-Hellman Encryption
In this scheme are two constants, PROOT and HEXMODULUS. The particular values chosen for these constants for the DES authentication protocol are:
const PROOT = 3;
const HEXMODULUS =	/* hex */
The way this scheme works is best explained by an example. Suppose there are two people, A and B, who want to send encrypted messages to each other. A and B each generate a random secret key that they do not disclose to anyone. Let these keys be represented as SK(A) and SK(B). They also publish in a public directory their public keys. These keys are computed as follows:
The ** notation is used here to represent exponentiation.
Now, both A and B can arrive at the common key between them, represented here as CK(A,B), without disclosing their secret keys.
A computes:
CK(A, B) = (PK(B) ** SK(A)) mod HEXMODULUS
while B computes:
CK(A, B) = (PK(A) ** SK(B)) mod HEXMODULUS
These two computations can be shown to be equivalent: (PK(B)**SK(A)) mod HEXMODULUS = (PK(A)**SK(B)) mod HEXMODULUS. Drop the mod HEXMODULUS parts and assume modulo arithmetic to simplify the process:
PK(B) ** SK(A) = PK(A) ** SK(B)
Then replace PK(B) by what B computed earlier and likewise for PK(A).
((PROOT ** SK(B)) ** SK(A) = (PROOT ** SK(A)) ** SK(B)
which leads to:
PROOT ** (SK(A) * SK(B)) = PROOT ** (SK(A) * SK(B))
This common key CK(A,B) is not used to encrypt the timestamps used in the protocol. It is used only to encrypt a conversation key that is then used to encrypt the timestamps. This approach uses the common key as little as possible, to prevent a break. Breaking the conversation key is a far less serious compromise, because conversations are comparatively short lived.
The conversation key is encrypted using 56-bit DES keys, yet the common key is 192 bits. To reduce the number of bits, 56 bits are selected from the common key as follows. The middle-most 8 bytes are selected from the common key, and then parity is added to the lower-order bit of each byte, producing a 56-bit key with 8 bits of parity.
