ONC+ Developer's Guide
Diffie-Hellman Encryption
In this scheme are two constants, PROOT and HEXMODULUS. The particular values chosen for these constants for the DES authentication protocol are:
const PROOT = 3;
const HEXMODULUS =	/* hex */
 "d4a0ba0250b6fd2ec626e7efd637df76c716e22d0944b88b";
The way this scheme works is best explained by an example. Suppose there are two people, A and B, who want to send encrypted messages to each other. A and B each generate a random secret key that they do not disclose to anyone. Let these keys be represented as SK(A) and SK(B). They also publish in a public directory their public keys. These keys are computed as follows:
PK(A) = (PROOT ** SK(A)) mod HEXMODULUS
PK(B) = (PROOT ** SK(B)) mod HEXMODULUS
The ** notation is used here to represent exponentiation.
Now, both A and B can arrive at the common key between them, represented here as CK(A,B), without disclosing their secret keys.
A computes:
CK(A, B) = (PK(B) ** SK(A)) mod HEXMODULUS
while B computes:
CK(A, B) = (PK(A) ** SK(B)) mod HEXMODULUS
These two computations can be shown to be equivalent: (PK(B)**SK(A)) mod HEXMODULUS = (PK(A)**SK(B)) mod HEXMODULUS. Drop the mod HEXMODULUS parts and assume modulo arithmetic to simplify the process:
PK(B) ** SK(A) = PK(A) ** SK(B)
Then replace PK(B) by what B computed earlier and likewise for PK(A).
((PROOT ** SK(B)) ** SK(A) = (PROOT ** SK(A)) ** SK(B)
which leads to:
PROOT ** (SK(A) * SK(B)) = PROOT ** (SK(A) * SK(B))
This common key CK(A,B) is not used to encrypt the timestamps used in the protocol. It is used only to encrypt a conversation key that is then used to encrypt the timestamps. This approach uses the common key as little as possible, to prevent a break. Breaking the conversation key is a far less serious compromise, because conversations are comparatively short lived.
The conversation key is encrypted using 56-bit DES keys, yet the common key is 192 bits. To reduce the number of bits, 56 bits are selected from the common key as follows. The middle-most 8 bytes are selected from the common key, and then parity is added to the lower-order bit of each byte, producing a 56-bit key with 8 bits of parity.
