ONC+ Developer's Guide
RPCL Unions
XDR unions are discriminated unions, and do not look like C unions. They are more similar to Pascal variant records.
union-definition:
	"union" union-ident "switch" "("simple declaration")" "{"
 		case-list
case-list:
 	"case" value ":" declaration ";"
 	"case" value ":" declaration ";" case-list
 	"default" ":" declaration ";"
The following example is of a type returned as the result of a “read data” operation: if no error occurs, return a block of data. Otherwise, don't return anything.
union read_result switch (int errno) {
 	case 0:
 		opaque data[1024];
 	default:
 		void;
This union compiles into the following:
struct read_result {
 	int errno;
 	union {
 		char data[1024];
 	} read_result_u;
typedef struct read_result read_result;
Notice that the union component of the output struct has the same name as the type name, except for the trailing _u.
