Another opportunity to use cookies is with callbacks. By using the rpc_gss_set_callback() function, a server can specify a user-defined callback so that it knows when a context first gets used. The callback is invoked the first time a context is used for data exchanges, after the context is established for the specified program and version.
The user-defined callback routine takes the following form:
bool_t callback (struct svc_req *req, gss_cred_id_t deleg, gss_ctx_id_t gss_context rpc_gss_lock_t * lock void ** cookie);
The second and third arguments, deleg and gss_context, are GSS-API data types and are currently exposed. See the GSS-API Programming Guide for more information. Note that deleg is the identity of any delegated peer, while gss_context is a pointer to the GSS-API context. This pointer is necessary in case the program needs to perform GSS-API operations on the context, that is, to test for acceptance criteria. You have already seen the cookie argument.
The lock argument is a pointer to a rpc_gss_lock_t structure:
typedef struct { bool_t locked; rpc_gss_rawcred_t *raw_cred; } rpc_gss_lock_t;
This parameter enables a server to enforce a particular QOP and service for the session. QOP and service are found in the rpc_gss_rawcred_t structure described in Example 5–14. A server should not change the values for service and QOP. When the user-defined callback is invoked, the locked field is set to FALSE. If the server sets locked to TRUE, only requests with QOP and service values that match the QOP and service values in the rpc_gss_rawcred_t structure are accepted.
For more information, see the rpc_gss_set_callback(3NSL) man page.
