The following table summarizes RPCSEC_GSS commands. It is a general overview of RPCSEC_GSS functions, rather than a specific description of each one. For more information on each function, see its man page, or check the rpcsec_gss(3NSL) man page for an overview, including a list of RPCSEC_GSS data structures.
Table 5–2 RPCSEC_GSS FunctionsAction | Function | Input | Output |
Create a security context | rpc_gss_seccreate(3NSL) | CLIENT handle, principal name, mechanism, QOP, service type | AUTH handle |
Change QOP, service type for context | rpc_gss_set_defaults(3NSL) | Old QOP, service | New QOP, service |
Show maximum size for data before security transformation | rpc_gss_max_data_length(3NSL) (client side) | Maximum data size allowed by transport | Maximum pre-transformation data size |
Show maximum size for data before security transformation | rpc_gss_svc_max_data_length(3NSL) (server side) | Maximum data size allowed by transport | Maximum pre-transformation data size |
Set name of principals for server to represent | rpc_gss_set_svc_name(3NSL) | Principal name, RPC program, version #s | TRUE if successful |
Fetch credentials of caller (client) | rpc_gss_getcred(3NSL) | Pointer to svc_req structure | UNIX credentials, RPCSEC_GSS credentials, cookie |
Specify user-written callback function | rpc_gss_set_callback(3NSL) | Pointer to callback function | TRUE if successful |
Create RPCSEC_GSS structure for principal names from unique parameters | rpc_gss_get_principal_name(3NSL) | Mechanism, user name, machine name, domain name | RPCSEC_GSS principal name structure |
Fetch an error code when an RPCSEC_GSS routine fails | rpc_gss_get_error(3NSL) |
| RPCSEC_GSS error number, errno if applicable |
Get strings for installed mechanisms | rpc_gss_get_mechanisms(3NSL) |
| List of valid mechanisms |
Get valid QOP strings | rpc_gss_get_mech_info(3NSL) | Mechanism | Valid QOPs for that mechanism |
Get the highest, lowest version numbers of RPCSEC_GSS supported | rpc_gss_get_versions(3NSL) |
| Highest, lowest versions |
Check if a mechanism is installed | rpc_gss_is_installed(3NSL) | Mechanism | TRUE if installed |
Convert ASCII mechanism to RPC object identifier | rpc_gss_mech_to_oid(3NSL) | Mechanism (as string) | Mechanism (as OID) |
Convert ASCII QOP to integer | rpc_gss_qop_to_num(3NSL) | QOP (as string) | QOP (as integer) |
