ONC+ Developer's Guide
Authentication Using RPCSEC_GSS
A determined snoop can overcome the authentication flavors mentioned previously- AUTH_SYS, AUTH_DES, and AUTH_KERB. For this reason a new networking layer, the Generic Security Standard API, or GSS-API, was added, which RPC programmers can use. The GSS-API framework offers two extra services beyond authentication: integrity and privacy.
Note –
Currently, the GSS–API is exposed, and certain GSS-API features are visible through RPCSEC_GSS functions. See the GSS-API Programming Guide.
The RPCSEC_GSS security flavor enables ONC RPC applications to maximize the features of GSS-API. RPCSEC_GSS sits “on top” of the GSS-API layer as shown in the following figure.
Figure 5–1 GSS-API and RPCSEC_GSS Security Layers
RPSEC_GSS is between the application and GSS-API.
Using the programming interface for RPCSEC_GSS, ONC RPC applications can specify the following information:
Applications can obtain lists of valid QOPs and mechanisms through functions provided by RPCSEC_GSS. See Miscellaneous Functions. Developers should avoid hard-coding mechanisms and QOPs into their applications, so that the applications do not need to be modified to use new or different mechanisms and QOPs.
Note –
Historically, “security flavor” and “authentication flavor” have had the same meaning. With the introduction of RPCSEC_GSS, “flavor” now has a somewhat different sense. A flavor can now include a service integrity or privacy along with authentication, although currently RPCSEC_GSS is the only flavor that falls into this category.
Using RPCSEC_GSS, ONC RPC applications establish a security context with a peer, exchange data, and destroy the context, just as they do with other flavors. After a context is established, the application can change the QOP and service for each data unit sent.
For more information on RPCSEC_GSS, including RPCSEC_GSS data types, see the rpcsec_gss(3N) man page.
The following table summarizes RPCSEC_GSS commands. It is a general overview of RPCSEC_GSS functions, rather than a specific description of each one. For more information on each function, see its man page, or check the rpcsec_gss(3NSL) man page for an overview, including a list of RPCSEC_GSS data structures.
Table 5–2 RPCSEC_GSS Functions
 Create a security contextrpc_gss_seccreate(3NSL) CLIENT handle, principal name, mechanism, QOP, service typeAUTH handle
 Change QOP, service type for contextrpc_gss_set_defaults(3NSL) Old QOP, service New QOP, service
 Show maximum size for data before security transformationrpc_gss_max_data_length(3NSL) (client side) Maximum data size allowed by transport Maximum pre-transformation data size
 Show maximum size for data before security transformationrpc_gss_svc_max_data_length(3NSL) (server side) Maximum data size allowed by transport Maximum pre-transformation data size
 Set name of principals for server to representrpc_gss_set_svc_name(3NSL) Principal name, RPC program, version #s TRUE if successful
 Fetch credentials of caller (client)rpc_gss_getcred(3NSL)Pointer to svc_req structure UNIX credentials, RPCSEC_GSS credentials, cookie
 Specify user-written callback function rpc_gss_set_callback(3NSL) Pointer to callback function TRUE if successful
 Create RPCSEC_GSS structure for principal names from unique parametersrpc_gss_get_principal_name(3NSL) Mechanism, user name, machine name, domain name RPCSEC_GSS principal name structure
 Fetch an error code when an RPCSEC_GSS routine failsrpc_gss_get_error(3NSL)
RPCSEC_GSS error number, errno if applicable
 Get strings for installed mechanismsrpc_gss_get_mechanisms(3NSL)
 List of valid mechanisms
 Get valid QOP stringsrpc_gss_get_mech_info(3NSL) Mechanism Valid QOPs for that mechanism
 Get the highest, lowest version numbers of RPCSEC_GSS supportedrpc_gss_get_versions(3NSL)
 Highest, lowest versions
 Check if a mechanism is installedrpc_gss_is_installed(3NSL) Mechanism TRUE if installed
 Convert ASCII mechanism to RPC object identifierrpc_gss_mech_to_oid(3NSL) Mechanism (as string) Mechanism (as OID)
 Convert ASCII QOP to integerrpc_gss_qop_to_num(3NSL) QOP (as string) QOP (as integer)
Creating a Context
You create contexts with the rpc_gss_seccreate() call. This function takes as its arguments:
This function returns an AUTH authentication handle. The following example shows how rpc_gss_seccreate() might be used to create a context using the Kerberos V5 security mechanism and the integrity service.
Example 5–10 rpc_gss_seccreate()
CLIENT *clnt;                    /* client handle */
char server_host[] = "foo";
char service_name[] = "nfs@eng.acme.com";
char mech[] = "kerberos_v5";
clnt = clnt_create(server_host, SERVER_PROG, SERV_VERS, "netpath");
clnt->clnt_auth = rpc_gss_seccreate(clnt, service_name, mech,
                          rpc_gss_svc_integrity, NULL, NULL, NULL);
Note the following points about the example:
For more information, see the rpc_gss_seccreate(3NSL) man page.
Changing Values and Destroying a Context
After a context has been set, the application might need to change QOP and service values for individual data units being transmitted. For example, if you want a program to encrypt a password but not a login name, you can use rpc_gss_set_defaults().
Example 5–11 rpc_gss_set_defaults ()
rpc_gss_set_defaults(clnt->clnt_auth, rpc_gss_svc_privacy, qop);
In this case, the security service is set to privacy. See Creating a Context. qop is a pointer to a string naming the new QOP.
Contexts are destroyed in the usual way, with auth_destroy().
For more information on changing service and QOP, see the rpc_gss_set_defaults(3NSL) man page.
Principal Names
You need both a client and a server principal name to establish and maintain a security context.
Setting Server Principal Names
A server needs to be told the names of the principals it represents when it starts up. A server can act as more than one principal. rpc_gss_set_svc_name() sets the name of the principals, as shown in the following code example.
Example 5–12 rpc_gss_set_svc_name()
char *principal, *mechanism;
u_int req_time;
principal = "nfs@eng.acme.com";
mechanism = "kerberos_v5";
req_time = 10000;		/* time for which credential should be valid */
rpc_gss_set_svc_name(principal, mechanism, req_time, SERV_PROG, SERV_VERS);
Kerberos ignores the req_time parameter. Other authentication systems might use it.
For more information, see the rpc_gss_set_svc_name(3NSL) man page.
Generating Client Principal Names
Servers need to be able to operate on a client's principal name. For example, you might need to compare a client's principal name to an access control list, or look up a UNIX credential for that client, if such a credential exists. Such principal names are kept in the form of a rpc_gss_principal_t structure pointer. See the rpcsec_gss(3NSL) man page for more on rpc_gss_principal_t. If a server is to compare a principal name it has received with the name of a known entity, the server needs to be able to generate a principal name in that form.
The rpc_gss_get_principal_name() call takes as input several parameters that uniquely identify an individual on a network, and generates a principal name as a rpc_gss_principal_t structure pointer, as shown in the following code example.
Example 5–13 rpc_gss_get_principal_name()
rpc_gss_principal_t *principal;
rpc_gss_get_principal_name(principal, mechanism, name, node, domain);
The arguments to rpc_gss_get_principal_name() are:
Each security mechanism requires different identifying parameters. For example, Kerberos V5 requires a user name and, only optionally, qualified node and domain names, which in Kerberos terms are host and realm names.
For more information, see the rpc_gss_get_principal_name(3NSL) man page.
Freeing Principal Names
Use the free() library call to free principal names.
Receiving Credentials at the Server
A server must be able to fetch the credentials of a client. The rpc_gss_getcred() function, shown in Example 5–14, enables the server to retrieve either UNIX credentials or RPCSEC_GSS credentials, or both. The function has two arguments that are set if the function is successful. One is a pointer to an rpc_gss_ucred_t structure, which contains the caller's UNIX credentials, if such exist:
typedef struct {
    uid_t   uid;          /* user ID */
    gid_t   gid;          /* group ID */
    short   gidlen;
    git_t   *gidlist;     /* list of groups */
} rpc_gss_ucred_t;
The other argument is a pointer to a rpc_gss_raw_cred_t structure, which looks like this:
typedef struct {
	u_int  version;              /*RPCSEC_GS program version *mechanism;
          	char          *qop;
	rpc_gss_principal_t client_principal;  /* client principal name */
	char                   *svc_principal; /*server principal name */
	rpc_gss_service_t	  service;        /* privacy, integrity enum */
} rpc_gss_rawcred_t;
Because rpc_gss_rawcred_t contains both the client and server principal names, rpc_gss_getcred() can return them both. See Generating Client Principal Names for a description of the rpc_gss_principal_t structure and how it is created.
The following example is a simple server-side dispatch procedure, in which the server gets the credentials for the caller. The procedure gets the caller's UNIX credentials and then verifies the user's identity, using the mechanism, QOP, and service type found in the rpc_gss_rcred_t argument.
Example 5–14 Getting Credentials
static void server_prog(struct svc_req *rqstp, SVCXPRT *xprt)
		rpc_gss_ucred_t *ucred;
		rpc_gss_rawcred_t *rcred;
		if (rqst->rq_proq == NULLPROC) {
			svc_sendreply(xprt, xdr_void, NULL);
		 * authenticate all other requests */
		switch (rqstp->rq_cred.oa_flavor) {
		case RPCSEC_GSS:
			 * get credential information
			rpc_gss_getcred(rqstp, &rcred, &ucred, NULL);
			* verify that the user is allowed to access
			* using received security parameters by
			* peeking into my config file
			if (!authenticate_user(ucred->uid, rcred->mechanism,
				rcred->qop, rcred->service)) {
			break; 	/* allow the user in */
		} /* end switch */
		switch (rqstp->rq_proq) {
		case SERV_PROC1:
		/* usual request processing; send response ... */
For more information, see the rpc_gss_getcred(3NSL) man page.
In Example 5–14, the last argument to rpc_gss_getcred() (here, a NULL) is a user-defined cookie, with a value on return of whatever was specified by the server when the context was created. This cookie, a 4-byte value, can be used in any way appropriate for the application. RPC does not interpret the cookie. For example, the cookie can be a pointer or index to a structure that represents the context initiator. Instead of computing this value for every request, the server computes it at context-creation time, saving on request-processing time.
Another opportunity to use cookies is with callbacks. By using the rpc_gss_set_callback() function, a server can specify a user-defined callback so that it knows when a context first gets used. The callback is invoked the first time a context is used for data exchanges, after the context is established for the specified program and version.
The user-defined callback routine takes the following form:
bool_t callback (struct svc_req *req,  gss_cred_id_t deleg,
gss_ctx_id_t  gss_context rpc_gss_lock_t *
lock void ** cookie);
The second and third arguments, deleg and gss_context, are GSS-API data types and are currently exposed. See the GSS-API Programming Guide for more information. Note that deleg is the identity of any delegated peer, while gss_context is a pointer to the GSS-API context. This pointer is necessary in case the program needs to perform GSS-API operations on the context, that is, to test for acceptance criteria. You have already seen the cookie argument.
The lock argument is a pointer to a rpc_gss_lock_t structure:
typedef struct {
		bool_t              locked;
		rpc_gss_rawcred_t   *raw_cred;
} rpc_gss_lock_t;
This parameter enables a server to enforce a particular QOP and service for the session. QOP and service are found in the rpc_gss_rawcred_t structure described in Example 5–14. A server should not change the values for service and QOP. When the user-defined callback is invoked, the locked field is set to FALSE. If the server sets locked to TRUE, only requests with QOP and service values that match the QOP and service values in the rpc_gss_rawcred_t structure are accepted.
For more information, see the rpc_gss_set_callback(3NSL) man page.
Maximum Data Size
Two functions, rpc_gss_max_data_length() on the client side, and rpc_gss_svc_max_data_length() on the server side, are useful in determining how large a piece of data can be before it is transformed by security measures and sent “over the wire.” A security transformation such as encryption usually changes the size of a piece of transmitted data, most often enlarging it. To make sure that data won't be enlarged past a usable size, these two functions return the maximum pre-transformation size for a given transport.
For more information, see the rpc_gss_max_data_length(3NSL) man page.
You can use several functions for getting information about the installed security system.
Using these functions gives the programmer latitude in avoiding hard-coding security parameters in applications. (See Table 5–2 and the rpcsec_gss(3NSL) man page for a list of all RPCSEC_GSS functions.)
Associated Files
RPCSEC_GSS makes use of certain files to store information.
gsscred Table
When a server retrieves the client credentials associated with a request, the server can get either the client's principal name in the form of a rpc_gss_principal_t structure pointer or local UNIX credentials (UID) for that client. Services such as NFS require a local UNIX credential for access checking, but others might not. Those services can, for example, store the principal name directly in their own access control lists as a rpc_gss_principal_t structure.
Note –
The correspondence between a client's network credential (its principal name) and any local UNIX credential is not automatic. The local security administrator must be set up explicitly.
The gsscred file contains both the client's UNIX and network (for example, Kerberos V5) credentials. The network credential is the Hex-ASCII representation of the rpc_gss_principal_t structure. The gsscred file is accessed through XFN. Thus, this table can be implemented over files, NIS, or NIS+, or any future name service supported by XFN. In the XFN hierarchy, this table appears as this_org_unit/service/gsscred. Administrators can maintain the gsscred table with the use of the gsscred utility, which enables adding and deleting of users and mechanisms.
/etc/gss/qop and /etc/gss/mech
For convenience, RPCSEC_GSS uses string literals for representing mechanisms and quality of protection (QOP) parameters. The underlying mechanisms themselves, however, require mechanisms to be represented as object identifiers and QOPs as 32–bit integers. Additionally, for each mechanism, you need to specify the shared library that implements the services for that mechanism.
The /etc/gss/mech file stores the following information on all installed mechanisms on a system: the mechanism name, in ASCII; the mechanism's OID; the shared library implementing the services provided by this mechanism; and, optionally, the kernel module implementing the service. A sample line might look like this:
kerberos_v5   1.2.840.113554.1.2.2    gl/mech_krb5.so gl_kmech_krb5
For all mechanisms installed, the /etc/gss/qop file stores all the QOPs supported by each mechanism, both as an ASCII string and as its corresponding 32–bit integer.
Both /etc/gss/mech and /etc/gss/qop are created when security mechanisms are first installed on a given system.
Many of the in-kernel RPC routines use non-string values to represent mechanism and QOP. Therefore, applications can use the rpc_gss_mech_to_oid() and rpc_gss_qop_to_num() functions to get the non-string equivalents for these parameters, should they need to maximize use of those in-kernel routines.
