SPARC Assembly Language Reference Manual
B.3 Example 3
The pseudo-ops shown in this example are .align, .global, .type, and .size.
The following C subroutine:
int sum(a, b)
	int a, b;
	return(a + b);
can be translated into the following assembly code:
	.section			".text"
	.global			sum
	.align			4
	add		%o0,%o1,%o0				! (a + b) is done in the
							! delay slot of retl
	.type		sum,#function				! sum is of type function
	.size		sum,.-sum				! size of sum is the diff
							! of current location
							! counter and the initial
							! definition of sum
