SPARC Assembly Language Reference Manual
5.2 Integer Instructions
The notations described in Table 5–2 are commonly suffixed to assembler mnemonics (uppercase letters for architecture instruction names).
Table 5–2
Notation
Description
a
Instructions that deal with alternate space
b
Byte instructions
c
Reference to coprocessor registers
d
Doubleword instructions
f
Reference to floating-point registers
h
Halfword instructions
q
Quadword instructions
sr
Status register
Table 5–3 outlines the correspondence between SPARC hardware integer instructions and SPARC assembly language instructions.
The syntax of individual instructions is designed so that a destination operand (if any), which may be either a register or a reference to a memory location, is always the last operand in a statement.
Note –
In Table 5–3,
"bgeu,a label"
Table 5–3
Opcode
Mnemonic
Argument List
Operation
Comments
ADD
add
regrs1, reg_or_imm, regrd
Add
ADDcc
addcc
Add and modify icc
ADDX
addx
Add with carry
ADDXcc
addxcc
AND
and
And
ANDcc
andcc
ANDcc
andn
ANDNcc
andcc
BN
bn{,a}
label
Branch on integer condition codes
branch never
BNE
bne{,a}
label
synonym: bnz
BE
BG
BLE
BGE
BI
BGU
BLEU
be{,a}
bg{,a}
ble{,a}
bge{,a}
bl{,a}
bgu{,a}
bleu{,a}
label
label
label
label
label
label
label
synonym: bz
BCC
bcc{,a}
label
synonym: bgeu
BCS
BPOS
BNEG
BVC
BVS
bcs{,a}
bpos{,a}
bneg{,a}
bvc{,a}
bvs{,a}
label
label
label
label
label
synonym: blu
BA
ba{,a}
label
synonym: b
CALL
call
label
Call subprogram
CBccc
cbn{,a}
cb3{,a}
cb2{,a}
cb23{,a}
cb1{,a}
cb13{,eo}
cb12{,a}
cb123{,a}
cb0{,a}
cb03{,a}
cb02{,a}
cb023{,a}
cb01{,a}
cb013{,a}
cb012{,a}
cba{,a}
label
label
label
label
label
label
label
label
label
label
label
label
label
label
label
label
Branch on coprocessor condition codes
branch never
FBN
FBU
FBG
FBUG
FBL
FBUL
FBLG
fbn{,a}
fbu{,a}
fbg{,a}
fbug{,a}
fbl{,a}
fbul{,a}
fblg{,a}
label
label
label
label
label
label
label
Branch on floating-point condition codes
branch never
FBNE
fbne{,a}
label
synonym: fbnz
FBE
fbe{,a}
label
synonym: fbz
FBUE
FBGE
FBUGE
FBLE
FBULE
FBO
FBA
fbue{,a}
fbge{,a}
fbuge{,a}
fble{,a}
fbule{,a}
fbo{,a}
fba{,a}
label
label
label
label
label
label
label
FLUSH
flush
address
Instruction cache flush
JMPL
jmpl
address, regrd
Jump and link
LDSB
ldsb
[address], regrd
Load signed byte
LDSH
ldsh
[address], regrd
Load signed halfword
LDSTUB
ldstub
[address], regrd
Load-store unsigned byte
LDUB
ldub
[address], regrd
Load unsigned byte
LDUH
lduh
[address], regrd
Load unsigned halfword
LD
ld
[address], regrd
Load word
LDD
ldd
[address], regrd
Load double word
regrd must be even
LDF
ld
[address], fregrd
LDFSR
ld
[address], %fsr
Load floating-point register
LDDF
ldd
[address], fregrd
Load double floating-point
fregrd must be even
LDC
ld
[address], cregrd
Load coprocessor
LDCSR
ld
[address], %csr
Load double coprocessor
LDDC
ldd
[address], cregrd
LDSBA
LDSHA
LDUBA
LDUHA
LDA
ldsba
ldsha
lduba
lduha
lda
[regaddr]asi, regrd
[regaddr]asi, regrd
[regaddr]asi, regrd
[regaddr]asi, regrd
[regaddr]asi, regrd
Load signed byte from alternate space
LDDA
ldda
[regaddr]asi, regrd
regrd must be even
LDSTUBA
ldstuba
[regaddr]asi, regrd
MULScc
mulscc
Multiply step (and modify icc)
NOP
nop
No operation
OR
ORcc
ORN
ORNcc
or
orcc
orn
orncc
Inclusive or
RDASR
rd
%asrnrs1, regrd
RDY
rd
%y, regrd
See synthetic instructions.
RDPSR
rd
%psr, regrd
RDWIM
rd
%wim, regrd
RDTBR
rd
%tbr, regrd
RESTORE
restore
regrs1, reg_or_imm, reg rd
RETT
rett
address
Return from trap
SAVE
save
SDIV
sdiv
Signed divide
SDIVcc
sdivcc
Signed divide and modify icc
SMUL
smul
Signed multiply
SMULcc
smulcc
Signed multiply and modify icc
SETHI
sethi
const22, regrd
Set high 22 bits of register
sethi
%hi(value), regrd
SLL
sll
Shift left logical
SRL
srl
Shift right logical
SRA
sra
Shift right arithmetic
STB
stb
regrd, [address]
Store byte
Synonyms: stub, stsb
STH
sth
regrd, [address]
Store half-word
Synonyms: stuh, stsh
ST
st
regrd, [address]
STD
std
regrd, [address]
regrd Must be even
STF
st
fregrd, [address]
STDF
std
fregrd, [address]
STFSR
st
%fsr, [address]
Store floating-point status register
fregrd Must be even
STDFQ
std
%fq, [address]
Store double floating-point queue
STC
st
cregrd, [address]
Store coprocessor
cregrd Must be even
STDC
std
cregrd, [address]
cregrd Must be even
STCSR
st
%csr, [address]
STDCQ
std
%cq, [address]
Store double coprocessor
STBA
stba
regrd [regaddr]asi
Store byte into alternate space
Synonyms: stuba, stsba
STHA
stha
regrd [regaddr]asi
Synonyms: stuha, stsha
STA
sta
regrd, [regaddr]asi
STDA
stda
regrd, [regaddr]asi
regrd Must be even
SUB
sub
Subtract
SUBcc
subcc
Subtract and modify icc
SUBX
subx
Subtract with carry
SUBXcc
subxcc
SWAP
SWAPA
swap
swapa
[address], regrd
[regaddr]asi, regrd
Swap memory word
with register
Ticc
tn
software_trap_number
Trap on integer condition code
Trap never
tne
Note: Trap numbers 16-31 are reserved for the user. Currently-defined trap numbers are those defined in /usr/include/sys/trap.h
Synonym: tnz
te
tg
tle
tge
tl
tgu
Synonym: tz
tleu
Synonym: tcc
tlu
tgeu
tpos
tneg
Synonym: tcc
tvc
tvs
ta
Synonym: t
TADDcc
TSUBcc
taddcc
tsubcc
Tagged add and modify icc
TADDccTV
TSUBccTV
taddcctv
tsubcctv
Tagged add and modify icc and trap on overflow
UDIV
udiv
Unsigned divide
UDIVcc
udivcc
Unsigned divide and modify icc
UMUL
umul
Unsigned multiply
UMULcc
umulcc
Unsigned multiply and modify icc
UNIMP
unimp
const22
Illegal instruction
WRASR
wr
reg_or_imm, %asrnrs1
WRY
wr
regrs1, reg_or_imm, %y
WRPSR
wr
regrs1, reg_or_imm, %psr
WRWIM
wr
regrs1, reg_or_imm, %wim
WRTBR
wr
regrs1, reg_or_imm, %tbr
XNOR
XNORcc
xnor
xnorcc
Exclusive nor
XOR
XORcc
xor
xorcc
Exclusive or
