Solaris Volume Manager Administration Guide
Classes of Volumes
You create a volume as a RAID-0 (concatenation or stripe) volume, a RAID-1 (mirror) volume, a RAID-5 volume, or a soft partition.
You can use either the Enhanced Storage tool within the Solaris Management Console or the command-line utilities to create and administer volumes.
The following table summarizes the classes of volumes.
Table 3–2 Classes of Volumes
Volume
Description
RAID-0 (stripe or concatenation)
Can be used directly, or as the basic building block for mirrors. RAID-0 volumes do not directly provide data redundancy.
RAID-1 (mirror)
Replicates data by maintaining multiple copies. A RAID-1 volume is composed of one or more RAID-0 volumes that are called submirrors.
RAID-5
Replicates data by using parity information. In the case of disk failure, the missing data can be regenerated by using available data and the parity information. A RAID-5 volume is generally composed of slices. One slice's worth of space is allocated to parity information, but the parity is distributed across all slices in the RAID-5 volume.
Soft partition
Divides a slice or logical volume into one or more smaller, extensible volumes.
