Solaris Volume Manager Administration Guide
ProcedureHow to Check the Status of State Database Replicas
Steps
  1. Become superuser.
  2. To check the status of state database replicas, use one of the following methods:
    • From the Enhanced Storage tool within the Solaris Management Console, open the State Database Replicas node to view all existing state database replicas. For more information, see the online help.
    • Use the metadb command to view the status of state database replicas. Add the -i option to display an explanation of the status flags, as shown in the following example. See the metadb(1M).
Example 7–4 Checking the Status of All State Database Replicas
# metadb -i
        flags           first blk       block count
     a m  p  luo        16              8192            /dev/dsk/c0t0d0s7
     a    p  luo        8208            8192            /dev/dsk/c0t0d0s7
     a    p  luo        16400           8192            /dev/dsk/c0t0d0s7
     a    p  luo        16              8192            /dev/dsk/c1t3d0s1
      W   p  l          16              8192            /dev/dsk/c2t3d0s1
     a    p  luo        16              8192            /dev/dsk/c1t1d0s3
     a    p  luo        8208            8192            /dev/dsk/c1t1d0s3
     a    p  luo        16400           8192            /dev/dsk/c1t1d0s3
 r - replica does not have device relocation information
 o - replica active prior to last mddb configuration change
 u - replica is up to date
 l - locator for this replica was read successfully
 c - replica's location was in /etc/lvm/mddb.cf
 p - replica's location was patched in kernel
 m - replica is master, this is replica selected as input
 W - replica has device write errors
 a - replica is active, commits are occurring to this replica
 M - replica had problem with master blocks
 D - replica had problem with data blocks
 F - replica had format problems
 S - replica is too small to hold current data base
 R - replica had device read errors
A legend of all the flags follows the status. The characters in front of the device name represent the status. Uppercase letters indicate a problem status. Lowercase letters indicate an “Okay” status.
