Solaris Volume Manager Administration Guide
Viewing the Solaris Volume Manager Configuration
Tip –
The metastat command does not sort output. Pipe the output of the metastat -p command to the sort or grep commands for a more manageable listing of your configuration.
ProcedureHow to View the Solaris Volume Manager Volume Configuration
Step
    To view the volume configuration, use one of the following methods:
    • From the Enhanced Storage tool within the Solaris Management Console, open the Volumes node. For more information, see the online help.
    • Use the following form of the metastat command:
      # metastat -p -i component-name
      -p
      Specifies to show output in a condensed summary. This output is suitable for use in creating the md.tab file.
      -i
      Specifies to verify that RAID-1 (mirror) volumes, RAID-5 volumes, and hot spares can be accessed.
      component-name
      Specifies the name of the volume to view. If no volume name is specified, a complete list of components is displayed.
Example 20–1 Viewing the Solaris Volume Manager Volume Configuration
The following example illustrates output from the metastat command.
# metastat
d50: RAID
    State: Okay
    Interlace: 32 blocks
Original device:
        Device              Start Block  Dbase State        Reloc  Hot Spare
        c1t4d0s5                 330     No    Okay         Yes
        c1t5d0s5                 330     No    Okay         Yes
        c2t4d0s5                 330     No    Okay         Yes
        c2t5d0s5                 330     No    Okay         Yes
        c1t1d0s5                 330     No    Okay         Yes
        c2t1d0s5                 330     No    Okay         Yes
d1: Concat/Stripe
    Stripe 0:
        Device              Start Block  Dbase  Reloc
        c1t2d0s3                   0     No     Yes
d2: Concat/Stripe
    Stripe 0:
        c2t2d0s3                   0     No     Yes
d80: Soft Partition
    Device: d70
    State: Okay
        Extent              Start Block              Block count
             0                        1                  2097152
d81: Soft Partition
    Device: d70
    State: Okay
             0                  2097154                  2097152
d70: Mirror
    Submirror 0: d71
      State: Okay
    Submirror 1: d72
      State: Okay
    Pass: 1
    Read option: roundrobin (default)
    Write option: parallel (default)
d71: Submirror of d70
    State: Okay
    Stripe 0:
        c1t3d0s3                   0     No    Okay         Yes
    Stripe 1:
        c1t3d0s4                   0     No    Okay         Yes
    Stripe 2:
        c1t3d0s5                   0     No    Okay         Yes
d72: Submirror of d70
    State: Okay
    Stripe 0:
        c2t3d0s3                   0     No    Okay         Yes
    Stripe 1:
        c2t3d0s4                   0     No    Okay         Yes
    Stripe 2:
        c2t3d0s5                   0     No    Okay         Yes
hsp010: is empty
hsp014: 2 hot spares
        Device              Status      Length          Reloc
        c1t2d0s1            Available    617652 blocks  Yes
        c2t2d0s1            Available    617652 blocks  Yes
hsp050: 2 hot spares
        c1t2d0s5            Available    4197879 blocks Yes
        c2t2d0s5            Available    4197879 blocks Yes
hsp070: 2 hot spares
        c1t2d0s4            Available    4197879 blocks Yes
        c2t2d0s4            Available    4197879 blocks Yes
Device Relocation Information:
Device              Reloc       Device ID
c1t2d0              Yes         id1,sd@SSEAGATE_ST39204LCSUN9.0G3BV0N1S200002103AF29
c2t2d0              Yes         id1,sd@SSEAGATE_ST39204LCSUN9.0G3BV0P64Z00002105Q6J7
c1t1d0              Yes         id1,sd@SSEAGATE_ST39204LCSUN9.0G3BV0N1EM00002104NP2J
c2t1d0              Yes         id1,sd@SSEAGATE_ST39204LCSUN9.0G3BV0N93J000071040L3S
c0t0d0              Yes         id1,dad@s53554e575f4154415f5f53543339313430412525415933
Example 20–2 Viewing a Multi-Terabyte Solaris Volume Manager Volume
The following example illustrates output from the metastat command for a multi-terabyte storage volume (11 Tbytes).
# metastat d0
 d0: Concat/Stripe
    Size: 25074708480 blocks (11 TB)
    Stripe 0: (interlace: 32 blocks)
        c27t8d3s0          0     No     Yes
        c4t7d0s0       12288     No     Yes
    Stripe 1: (interlace: 32 blocks)
        c13t2d1s0      16384     No     Yes
        c13t4d1s0      16384     No     Yes
        c13t6d1s0      16384     No     Yes
        c13t8d1s0      16384     No     Yes
        c16t3d0s0      16384     No     Yes
        c16t5d0s0      16384     No     Yes
        c16t7d0s0      16384     No     Yes
        c20t4d1s0      16384     No     Yes
        c20t6d1s0      16384     No     Yes
        c20t8d1s0      16384     No     Yes
        c9t1d0s0       16384     No     Yes
        c9t3d0s0       16384     No     Yes
        c9t5d0s0       16384     No     Yes
        c9t7d0s0       16384     No     Yes
    Stripe 2: (interlace: 32 blocks)
        c27t8d2s0      16384     No     Yes
        c4t7d1s0       16384     No     Yes
    Stripe 3: (interlace: 32 blocks)
        c10t7d0s0      32768     No     Yes
        c11t5d0s0      32768     No     Yes
        c12t2d1s0      32768     No     Yes
        c14t1d0s0      32768     No     Yes
        c15t8d1s0      32768     No     Yes
        c17t3d0s0      32768     No     Yes
        c18t6d1s0      32768     No     Yes
        c19t4d1s0      32768     No     Yes
        c1t5d0s0       32768     No     Yes
        c2t6d1s0       32768     No     Yes
        c3t4d1s0       32768     No     Yes
        c5t2d1s0       32768     No     Yes
        c6t1d0s0       32768     No     Yes
        c8t3d0s0       32768     No     Yes
Where To Go From Here
For more information, see the metastat(1M) man page.
