Solaris Volume Manager Administration Guide
ProcedureHow to Replace a Failed Disk
Steps
  1. Identify the failed disk to be replaced by examining the /var/adm/messages file and the metastat command output.
  2. Locate any state database replicas that might have been placed on the failed disk.
    Use the metadb command to find the replicas.
    The metadb command might report errors for the state database replicas that are located on the failed disk. In this example, c0t1d0 is the problem device.
    # metadb
       flags       first blk        block count
      a m     u        16               1034            /dev/dsk/c0t0d0s4
      a       u        1050             1034            /dev/dsk/c0t0d0s4
      a       u        2084             1034            /dev/dsk/c0t0d0s4
      W   pc luo       16               1034            /dev/dsk/c0t1d0s4
      W   pc luo       1050             1034            /dev/dsk/c0t1d0s4
      W   pc luo       2084             1034            /dev/dsk/c0t1d0s4
    The output shows three state database replicas on each slice 4 of the local disks, c0t0d0 and c0t1d0. The W in the flags field of the c0t1d0s4 slice indicates that the device has write errors. Three replicas on the c0t0d0s4 slice are still good.
  3. Record the slice name where the state database replicas reside and the number of state database replicas. Then, delete the state database replicas.
    The number of state database replicas is obtained by counting the number of appearances of a slice in the metadb command output. In this example, the three state database replicas that exist on c0t1d0s4 are deleted.
    # metadb -d c0t1d0s4
    Caution – Caution –
    If, after deleting the bad state database replicas, you are left with three or fewer, add more state database replicas before continuing. Doing so helps to ensure that configuration information remains intact.
  4. Locate and delete any hot spares on the failed disk.
    Use the metastat command to find hot spares. In this example, hot spare pool hsp000 included c0t1d0s6, which is then deleted from the pool.
    # metahs -d hsp000 c0t1d0s6
    hsp000: Hotspare is deleted
  5. Replace the failed disk.
    This step might entail using the cfgadm command, the luxadm command, or other commands as appropriate for your hardware and environment. When performing this step, make sure to follow your hardware's documented procedures to properly manipulate the Solaris state of this disk.
  6. Repartition the new disk.
    Use the format command or the fmthard command to partition the disk with the same slice information as the failed disk. If you have the prtvtoc output from the failed disk, you can format the replacement disk with the fmthard -s /tmp/failed-disk-prtvtoc-output command.
  7. If you deleted state database replicas, add the same number back to the appropriate slice.
    In this example, /dev/dsk/c0t1d0s4 is used.
    # metadb -a -c 3 c0t1d0s4
  8. If any slices on the disk are components of RAID-5 volumes or are components of RAID-0 volumes that are in turn submirrors of RAID-1 volumes, run the metareplace -e command for each slice.
    In this example, /dev/dsk/c0t1d0s4 and mirror d10 are used.
    # metareplace -e d10 c0t1d0s4
  9. If any soft partitions are built directly on slices on the replaced disk, run the metarecover -m -p command on each slice that contains soft partitions. This command regenerates the extent headers on disk.
    In this example, /dev/dsk/c0t1d0s4 needs to have the soft partition markings on disk regenerated. The slice is scanned and the markings are reapplied, based on the information in the state database replicas.
    # metarecover c0t1d0s4 -m -p
  10. If any soft partitions on the disk are components of RAID-5 volumes or are components of RAID-0 volumes that are submirrors of RAID-1 volumes, run the metareplace -e command for each slice.
  11. If any RAID-0 volumes have soft partitions built on them, run the metarecover command for each RAID-0 volume.
    In this example, RAID-0 volume, d17, has soft partitions built on it.
    # metarecover d17 -m -p
  12. Replace hot spares that were deleted, and add them to the appropriate hot spare pool or pools.
    In this example, hot spare pool, hsp000 included c0t1d0s6. This slice is added to the hot spare pool.
    # metahs -a hsp000 c0t1d0s6
    hsp000: Hotspare is added
  13. If soft partitions or nonredundant volumes were affected by the failure, restore data from backups. If only redundant volumes were affected, then validate your data.
    Check the user and application data on all volumes. You might have to run an application-level consistency checker, or use some other method to check the data.
