System Administration Guide: IP Services
Modifying DHCP Macros
You might need to modify macros when some aspect of your network changes and one or more DHCP clients need to know about the change. For example, you might add a router or an NIS server, create a new subnet, or change the lease policy.
Before you modify a macro, determine the name of the DHCP option you want to change, add, or delete. The standard DHCP options are listed in the DHCP Manager help and in the dhcp_inittab(4) man page.
You can use the dhtadm -M -m command or DHCP Manager to modify macros. See the dhtadm(1M) man page for more information about dhtadm.
The following figure shows DHCP Manager's Macro Properties dialog box.
Figure 15–15 Macro Properties Dialog Box in DHCP Manager
Dialog box shows list of options and their values. Shows
Select, Add, Modify, up and down, and Delete buttons. Shows check box to notify
server.
