System Administration Guide: IP Services
ProcedureHow to Enable Dynamic DNS Updating for DHCP Clients
Note –
Be aware that dynamic DNS updates are a security risk.
By default, the Oracle Solaris DNS daemon (in.named) does not allow dynamic updates. Authorization for dynamic DNS updates is granted in the named.conf configuration file on the DNS server system. No other security is provided. You must carefully weigh the convenience of this facility for users against the security risk created when you enable dynamic DNS updates.
  1. On the DNS server, edit the /etc/named.conf file as superuser.
  2. Find the zone section for the appropriate domain in the named.conf file.
  3. Add the DHCP server's IP addresses to the allow-update keyword.
    If the allow-update keyword does not exist, insert the keyword.
    For example, if the DHCP server resides at addresses and, a named.conf file for the zone should be modified as follows:
    zone "" in {
                 type master;
                 file "db.dhcp";
                 allow-update {;; };
    zone "10.IN-ADDR.ARPA" in {
                 type master;
                 file "db.10";
                 allow-update {;; };
    Note that allow-update for both zones must be enabled to allow the DHCP server to update both A and PTR records on the DNS server.
  4. On the DHCP server, start DHCP Manager.
    # /usr/sadm/admin/bin/dhcpmgr &
    See How to Start and Stop DHCP Manager for more detailed information.
  5. Choose Modify from the Service menu.
    The Modify Service Options dialog box opens.
  6. Select Update DNS Host Information Upon Client Request.
  7. Specify the number of seconds to wait for a response from the DNS server before timing out, then click OK.
    The default value of 15 seconds should be adequate. If you have time out problems, you can increase the value later.
  8. Click the Macros tab, and ensure that the correct DNS domain is specified.
    The DNSdmain option must be passed with the correct domain name to any client that expects dynamic DNS update support. By default, DNSdmain is specified in the server macro, which is used as the configuration macro bound to each IP address.
  9. Set up the DHCP client to specify its host name when requesting DHCP service.
    If you use the Oracle Solaris DHCP client, see How to Enable an Oracle Solaris DHCPv4 Client to Request a Specific Host Name. If your client is not a Oracle Solaris DHCP client, see the documentation for your DHCP client for information about how to specify a host name.
