System Administration Guide: IP Services
ProcedureHow to Modify IP Address Properties (pntadm)
  1. Become superuser or assume a role or user name that is assigned to the DHCP Management profile.
    For more information about the DHCP Management profile, see Setting Up User Access to DHCP Commands.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Modify IP address properties by typing a command of the following format:
    # pntadm -M ip-address options network-address
    Many options can be used with the pntadm command, which are documented in the pntadm(1M) man page.
    Table 15–4 shows some sample pntadm commands that specify options.
