System Administration Guide: IP Services
Supporting Oracle Solaris Network Installation With the DHCP Service
You can use DHCP to install Oracle Solaris on certain client systems on your network. Only sun4u-based systems and x86 systems that meet the hardware requirements for running Oracle Solaris can use this feature. For information about using DHCP to automatically configure client systems for the network as they boot, see Chapter 2, Preconfiguring System Configuration Information (Tasks), in Oracle Solaris 10 9/10 Installation Guide: Network-Based Installations.
DHCP also supports Oracle Solaris client systems that boot and install remotely from servers across a wide area network (WAN) using HTTP. This method of remote booting and installing is called the WAN boot installation method. Using WAN boot, you can install Oracle Solaris on SPARC based systems over a large public network where the network infrastructure might be untrustworthy. You can use WAN boot with security features to protect data confidentiality and installation image integrity.
Before you can use DHCP for booting and installing client systems remotely using WAN boot, the DHCP server must be configured to supply the following information to clients:
For details about configuring the DHCP server to provide this information, see Chapter 2, Preconfiguring System Configuration Information (Tasks), in Oracle Solaris 10 9/10 Installation Guide: Network-Based Installations. For information about booting and installing client systems with a DHCP server across a WAN, see Chapter 10, WAN Boot (Overview), in Oracle Solaris 10 9/10 Installation Guide: Network-Based Installations.
For information about supporting diskless clients, see Supporting Remote Boot and Diskless Boot Clients (Task Map).
