System Administration Guide: IP Services
Removing DHCP Networks
DHCP Manager enables you to remove multiple networks at once. You have the option to automatically remove the hosts table entries associated with the DHCP-managed IP addresses on those networks as well. The following figure shows DHCP Manager's Delete Networks dialog box.
Figure 15–7 Delete Networks Dialog Box in DHCP Manager
Dialog box shows two lists, Keep Networks and Delete
Networks, with selection arrows between them. Check box for Delete host table
entries also shown.
The pntadm command requires you to delete each IP address entry from a network before you delete that network. You can delete only one network at a time.
