System Administration Guide: IP Services
ProcedureHow to Import Data on a DHCP Server (dhcpconfig -I)
  1. Log in to the server to which you want to import the data.
  2. Become superuser or assume a role or user name that is assigned to the DHCP Management profile.
    For more information about the DHCP Management profile, see Setting Up User Access to DHCP Commands.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  3. Import the data by typing a command of the following format:
    # dhcpconfig -I filename
    filename is the name of the file that contains the exported data.
  4. Modify the imported data, if necessary.
    See How to Modify Imported DHCP Data (pntadm, dhtadm).
