System Administration Guide: IP Services
ProcedureHow to Display Network Interface Status
The i option of the netstat command shows the state of the network interfaces that are configured on the local system. With this option, you can determine the number of packets a system transmits and receives on each network.
  1. Display the status of interfaces on the network.
    $ netstat -i
Example 8–8 Network Interface Status Display
The next example shows the status of IPv4 and IPv6 packet flow through the host's interfaces.
For example, the input packet count (Ipkts) that is displayed for a server can increase each time a client tries to boot, while the output packet count (Opkts) remains steady. This outcome suggests that the server is seeing the boot request packets from the client. However, the server does not know to respond to them. This confusion might be caused by an incorrect address in the hosts, ipnodes, or ethers database.
However, if the input packet count is steady over time, then the machine does not see the packets at all. This outcome suggests a different type of failure, possibly a hardware problem.
Name  Mtu  Net/Dest      Address        Ipkts  Ierrs Opkts  Oerrs Collis Queue
lo0   8232 loopback      localhost      142    0     142    0     0      0
hme0  1500 host58        host58        1106302 0     52419  0     0      0
lo0   8252 localhost     localhost                   142    0     142    0     0
hme0  1500 fe80::a00:20ff:feb9:4c54/10 fe80::a00:20ff:feb9:4c54 1106305 0 52422 0  0
