System Administration Guide: IP Services
How Name Services Affect Network Databases
The format of your network database depends on the type of name service you select for your network. For example, the hosts database contains, at least the host name and IPv4 address of the local system and any network interfaces that are directly connected to the local system. However, the hosts database could contain other IPv4 addresses and host names, depending on the type of name service on your network.
The network databases are used as follows:
Note –
DNS boot and data files do not correspond directly to the network databases.
The following figure shows the forms of the hosts database that are used by these name services.
Figure 10–2 Forms of the hosts Database Used by Name Services
This figure shows the various how the DNS, NIS,
NIS+ name services and local files store the hosts database.
The following table lists the network databases and their corresponding local files and NIS maps.
Note –
The ipnodes database is removed from Oracle Solaris releases after Solaris 10 11/06.
Table 10–1 Network Databases and Corresponding Name Service Files
Network Database
Local Files
NIS Maps
hosts
/etc/inet/hosts
hosts.byaddr hosts.byname
ipnodes
/etc/inet/ipnodes
ipnodes.byaddr ipnodes.byname
netmasks
/etc/inet/netmasks
netmasks.byaddr
ethers
/etc/ethers
ethers.byname ethers.byaddr
bootparams
/etc/bootparams
bootparams
protocols
/etc/inet/protocols
protocols.byname protocols.bynumber
services
/etc/inet/services
services.byname
networks
/etc/inet/networks
networks.byaddr networks.byname
This book discusses network databases as they are viewed by networks that use local files for name services.
Refer to System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP) for information on network databases correspondences in NIS, DNS, and LDAP.
