System Administration Guide: IP Services
bootparams Database
The bootparams database contains information that is used by systems that are configured to boot in network client mode. You need to edit this database if your network has network clients. See Configuring Network Clients for the procedures. The database is built from information that is entered into the /etc/bootparams file.
The bootparams(4) man page contains the complete syntax for this database. Basic syntax is shown here:
system-name file-key-server-name:pathname
For each network client system, the entry might contain the following information: the name of the client, a list of keys, the names of servers, and path names. The first item of each entry is the name of the client system. All items but the first item are optional. An example follows.
Example 10–7 bootparams Database
myclient   root=myserver : /nfsroot/myclient  \
swap=myserver : /nfsswap//myclient \
dump=myserver : /nfsdump/myclient
In this example, the term dump= tells client hosts not to look for a dump file.
Wildcard Entry for bootparams
In most instances, use the wildcard entry when editing the bootparams database to support clients. This entry follows:
*  root=server:/path dump=:
The asterisk (*) wildcard indicates that this entry applies to all clients that are not specifically named within the bootparams database.
