System Administration Guide: IP Services
ethers Database
The ethers database is built from information that is entered into the /etc/ethers file. This database associates host names to their Media Access Control (MAC) addresses. You need to create an ethers database only if you are running the RARP daemon. That is, you need to create this database if you are configuring network clients.
RARP uses the file to map MAC addresses to IP addresses. If you are running the RARP daemon in.rarpd, you need to set up the ethers file and maintain this file on all hosts that are running the daemon to reflect changes to the network.
The ethers(4) man page contains the complete syntax for this database. The basic syntax is shown here:
MAC-address   hostname   #comment
MAC address of the host
Official name of the host
Any note that you want to append to an entry in the file
The equipment manufacturer provides the MAC address. If a system does not display the MAC address during the system booting process, see your hardware manuals for assistance.
When adding entries to the ethers database, ensure that host names correspond to the primary names in the hosts and, for Solaris 10 11/06 and earlier releases, the ipnodes database, not to the nicknames, as follows.
Example 10–8 Entries in the ethers Database
8:0:20:1:40:16  fayoum
8:0:20:1:40:15  nubian
8:0:20:1:40:7   sahara    # This is a comment
8:0:20:1:40:14  tenere
