System Administration Guide: IP Services
ProcedureHow to Enable Logging of IPQoS Messages During Booting
  1. Assume the Primary Administrator role, or become superuser, on the IPQoS-enabled system.
    The Primary Administrator role includes the Primary Administrator profile. To create the role and assign the role to a user, see Chapter 2, Working With the Solaris Management Console (Tasks), in System Administration Guide: Basic Administration.
  2. Open the /etc/syslog.conf file.
  3. Add the following text as the final entry in the file.
    user.info                 /var/adm/messages
    Use tabs rather than spaces between the columns.
    The entry logs all boot-time messages that are generated by IPQoS into the /var/adm/messages file.
  4. Reboot the system to apply the messages.
Example 35–1 IPQoS Output From /var/adm/messages
When you view /var/adm/messages after system reboot, your output might contain IPQoS logging messages that are similar to the following.
May 14 10:44:33 ipqos-14 ipqosconf: [ID 815575 user.info]
 New configuration applied.
May 14 10:44:46 ipqos-14 ipqosconf: [ID 469457 user.info]
Current configuration saved to init file.
May 14 10:44:55 ipqos-14 ipqosconf: [ID 435810 user.info]
Configuration flushed.
You might also see IPQoS error messages that are similar to the following in your IPQoS system's /var/adm/messages file.
May 14 10:56:47 ipqos-14 ipqosconf: [ID 123217 user.error]
 Missing/Invalid config file fmt_version.
May 14 10:58:19 ipqos-14 ipqosconf: [ID 671991 user.error]
No ipgpc action defined.
For a description of these error messages, see Table 35–1.
