System Administration Guide: IP Services
params Clause
The params clause contains processing instructions for the module that is defined in the action statement. Use the following syntax for the params clause:
params {
           params-stats | ""
In the params clause, you use parameters that are applicable to the module.
The params-stats value in the params clause is either global_stats TRUE or global_stats FALSE. The global_stats TRUE instruction turns on UNIX style statistics for the action statement where global statistics is invoked. You can view the statistics by using the kstat command. You must enable action statement statistics before you can enable per-class statistics.
