Assume the Primary Administrator role, or become superuser, on the system where you want to enable Mobile IP.
The Primary Administrator role includes the Primary Administrator profile. To create the role and assign the role to a user, see Chapter 2, Working With the Solaris Management Console (Tasks), in System Administration Guide: Basic Administration.
Type the following command for each label that you want to modify in the GlobalSecurityParameters section:
# mipagentconfig change <label> <value> |
For example, if you are enabling home agent and foreign agent authentication, use the following command:
# mipagentconfig change HA-FAauth yes |
The following example shows how you might change other parameters in the configuration file's GlobalSecurityParameters section.
# mipagentconfig change MaxClockSkew 200 # mipagentconfig change MN-FAauth yes # mipagentconfig change Challenge yes # mipagentconfig change KeyDistribution files |
