You can use the mipagentconfig get command to display current settings that are associated with parameter destinations.
Assume the Primary Administrator role, or become superuser, on the system where you are enabling Mobile IP.
The Primary Administrator role includes the Primary Administrator profile. To create the role and assign the role to a user, see Chapter 2, Working With the Solaris Management Console (Tasks), in System Administration Guide: Basic Administration.
Type the following command for each parameter for which you want to display settings:
# mipagentconfig get [<parameter> | <label>] |
For example, if you are displaying the advertisement settings for the hme0 device, use the following command:
# mipagentconfig get adv hme0 |
As a result, the following output might be displayed:
[Advertisements hme0] HomeAgent = yes ForeignAgent = yes |
The following example shows the results of using the mipagentconfig get command with other parameter destinations.
# mipagentconfig get MaxClockSkew [GlobalSecurityParameters] MaxClockSkew=300 # mipagentconfig get HA-FAauth [GlobalSecurityParameters] HA-FAauth=no # mipagentconfig get MN-FAauth [GlobalSecurityParameters] MN-FAauth=no # mipagentconfig get Challenge [GlobalSecurityParameters] Challenge=no # mipagentconfig get Pool 10 [Pool 10] BaseAddress=192.168.1.1 Size=100 # mipagentconfig get SPI 257 [SPI 257] Key=11111111111111111111111111111111 ReplayMethod=none # mipagentconfig get SPI 258 [SPI 258] Key=15111111111111111111111111111111 ReplayMethod=none # mipagentconfig get addr 10.1.1.1 [Address 10.1.1.1] SPI=258 Type=agent # mipagentconfig get addr 192.168.1.200 [Address 192.168.1.200] SPI=257 Type=node |
