System Administration Guide: IP Services
ProcedureHow to Modify the General Section
  1. Assume the Primary Administrator role, or become superuser on the system where you want to enable Mobile IP.
    The Primary Administrator role includes the Primary Administrator profile. To create the role and assign the role to a user, see Chapter 2, Working With the Solaris Management Console (Tasks), in System Administration Guide: Basic Administration.
  2. On a command line, type the following command for each label that you want to modify in the General section.
    # mipagentconfig change <label> <value>
Example 28–1 Modifying a Parameter in the General Section
The following example shows how you might change the version number in the configuration file's General section.
# mipagentconfig change version 2
