System Administration Guide: IP Services
ProcedureHow to Configure the General Section
If you copied one of the sample files in the /etc/inet directory, you can omit this procedure because the sample file contains this entry. General Section provides descriptions of the labels and values that are used in this section.
  1. Edit the /etc/inet/mipagent.conf file and add the following lines:
         Version = 1.0
    Note –
    The /etc/inet/mipagent.conf file must contain this entry.
