System Administration Guide: IP Services
ProcedureHow to Configure the SPI Section
SPI Section provides descriptions of the labels and values that are used in this section.
  1. Edit the /etc/inet/mipagent.conf file.
  2. Add or change the following lines by using the values that are required for your configuration:
    [SPI SPI-identifier]
         ReplayMethod = <none/timestamps>
         Key = key
    Note –
    You must include a different SPI section for each security context that is deployed.
