System Administration Guide: IP Services
ProcedureHow to Configure the Address Section
Address Section provides descriptions of the labels and values that are used in this section.
  1. Edit the /etc/inet/mipagent.conf file.
  2. Add or change the following lines by using the values that are required for your configuration:
    • For a mobile node, use the following:
      [Address address]
           Type = node
           SPI = SPI-identifier
    • For an agent, use the following:
      [Address address]
           Type = agent
    • For a mobile node that is identified by its NAI, use the following:
      [Address NAI]
           Type = Node
           Pool = pool-identifier
    • For a default mobile node, use the following:
      [Address Node-Default]
           Type = Node
