System Administration Guide: IP Services
Pool Section
Mobile nodes can be assigned dynamic addresses by the home agent. Dynamic address assignment is done within the mipagent daemon independently of DHCP. You can create an address pool that can be used by mobile nodes by requesting a home address. Address pools are configured through the Pool section in the configuration file.
The Pool section contains the BaseAddress and Size labels. The Pool section has the following syntax:
[Pool pool-identifier]
     BaseAddress = IP-address
     Size = size
Note –
If you use a Pool identifier, then it must also exist in the mobile node's Address section.
You use the Pool section to define address pools that can be assigned to the mobile nodes. You use the BaseAddress label to set the first IP address in the pool. You use the Size label to specify the number of addresses available in the pool.
For example, if IP addresses 192.168.1.1 through 192.168.1.100 are reserved in pool 10, the Pool section has the following entry:
[Pool 10]
     BaseAddress = 192.168.1.1
     Size = 100
Note –
Address ranges should not encompass the broadcast address. For example, you should not assign BaseAddress = 192.168.1.200 and Size = 60, because this range encompasses the broadcast address 192.168.1.255.
The following table describes the labels and values that are used in the Pool section.
Table 29–3 Pool Section Labels and Values
Label
Value
Description
BaseAddress
n.n.n.n
First address in the address pool
Size
n
Number of addresses in the pool
