System Administration Guide: IP Services
mipagent.conf.fa-sample File
The following listing shows the sections, labels, and values that are contained in the mipagent.conf.fa-sample file. Configuration File Sections and Labels describes the syntax, sections, labels, and values.
The mipagent.conf.fa-sample file shows a configuration that provides only foreign agent functionality. This sample file does not contain a Pool section because pools are used only by a home agent. Otherwise, this file is the same as the mipagent.conf-sample file.
[General]
   Version = 1.0    # version number for the configuration file. (required)
[Advertisements hme0]
   HomeAgent = no
   ForeignAgent = yes
   PrefixFlags = yes
   AdvertiseOnBcast = yes
   RegLifetime = 200
   AdvLifetime = 200
   AdvFrequency = 5
   ReverseTunnel = yes
   ReverseTunnelRequired = no
[GlobalSecurityParameters]
   MaxClockSkew = 300
   HA-FAauth = yes
   MN-FAauth = yes
   Challenge = no
   KeyDistribution = files
[SPI 257]
   ReplayMethod = none
   Key = 11111111111111111111111111111111
[SPI 258]
   ReplayMethod = none
   Key = 15111111111111111111111111111111
[Address 10.1.1.1]
   Type = node
   SPI = 258
[Address 10.68.30.36]
   Type = agent
   SPI = 257
