This section describes some helpful tasks for queue administration. For information about the client-only queue, refer to submit.cf Configuration File From Version 8.12 of sendmail. For other related information, you can refer to Additional Queue Features From Version 8.12 of sendmail.
Refer to the following:
How to Display the Contents of the Mail Queue, /var/spool/mqueue
How to Force Mail Queue Processing in the Mail Queue, /var/spool/mqueue
Show how many messages are in the queue and how fast they are being cleared from the queue.
Type the following:
# /usr/bin/mailq | more |
This command provides the following information.
The queue IDs
The size of the message
The date that the message entered the queue
The message status
The sender and the recipients
Additionally, this command now checks for the authorization attribute, solaris.admin.mail.mailq. If the check is successful, the equivalent of specifying the -bp flag with sendmail is executed. If the check fails, an error message is printed. By default, this authorization attribute is enabled for all users. The authorization attribute can be disabled by modifying the user entry in prof_attr. For more information, refer to the man pages for prof_attr(4) and mailq(1).
Use this procedure, for example, to process messages to a system that was previously unable to receive messages.
Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
Force queue processing and display the progress of the jobs as the queue is cleared.
# /usr/lib/sendmail -q -v |
Use this procedure, for example, to force a substring of an address, such as a host name, to be processed. Also, use this procedure to force a particular message from the queue.
Run a subset of the mail queue at any time with -qRstring.
# /usr/lib/sendmail -qRstring |
Use a recipient's alias or a substring of user@host.domain, such as a host name.
Alternately, you can run a subset of the mail queue with -qInnnnn.
# /usr/lib/sendmail -qInnnnn |
Use a queue ID.
If you are moving the mail queue, follow these instructions.
Become root on the mail host or assume an equivalent role.
Kill the sendmail daemon.
# svcadm disable network/smtp:sendmail |
Now sendmail is no longer processing the queue directory.
Change to the /var/spool directory.
# cd /var/spool |
Move the directory, mqueue, and all its contents to the omqueue directory. Then create a new empty directory that is named mqueue.
# mv mqueue omqueue; mkdir mqueue |
Set the permissions of the directory to read/write/execute by owner, and read/execute by group. Also, set the owner and group to daemon.
# chmod 750 mqueue; chown root:bin mqueue |
Start sendmail.
# svcadm enable network/smtp:sendmail |
To run an old mail queue, follow these instructions.
Run the old mail queue.
# /usr/lib/sendmail -oQ/var/spool/omqueue -q |
The -oQ flag specifies an alternate queue directory. The -q flag says to run every job in the queue. Use the -v flag if you are displaying the verbose output on the screen.
Remove the empty directory.
# rmdir /var/spool/omqueue |
