System Administration Guide: Network Services
ProcedureHow to Disable .forward Files
This procedure, which prevents automated forwarding, disables the .forward file for a particular host.
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Make a copy of /etc/mail/cf/domain/solaris-generic.m4 or your site-specific domain m4 file.
    # cd /etc/mail/cf/domain
    # cp solaris-generic.m4 mydomain.m4
    mydomain
    Use the file name of your choice.
  3. Add the following line to the file that you just created.
    define(`confFORWARD_PATH',`')dnl
    If a value for confFORWARD_PATH already exists in the m4 file, replace the value with this null value.
  4. Build and install a new configuration file.
    If you need help with this step, refer to How to Build a New sendmail.cf File.
    Note –
    When you edit the .mc file, remember to change DOMAIN(`solaris-generic') to DOMAIN(`mydomain').
