System Administration Guide: Network Services
Changes for LDAP From Version 8.12 of sendmail
The following list describes changes in the use of the Lightweight Directory Access Protocol (LDAP) with sendmail.
The following example shows how these tokens differ for a “*” lookup.
Table 14–29 Comparison of Tokens
LDAP Map Specification
Specification Equivalent
Result
-k"uid=%s"
-k"uid=*"
Matches any record with a user attribute
-k"uid=%0"
-k"uid=\2A"
Matches a user with the name “*
The following table describes additional LDAP map flags.
Table 14–30 Additional LDAP Map Flags
Flag
Description
-1
Requires a single match to be returned. If more than one match is returned, the results are the equivalent of no records being found.
-r never|always|search|find
Sets the LDAP alias dereference option.
-Z size
Limits the number of matches to return.
