Within the /etc/mail directory is a subdirectory, cf, that contains all of the necessary files to build a sendmail.cf file. The content of cf is shown in Table 14–9.
Starting in the Solaris 10 release, to support a read-only /usr file system, the content of the /usr/lib/mail directory has been moved to the /etc/mail/cf directory. Note, however, these exceptions. The shell scripts /usr/lib/mail/sh/check-hostname and /usr/lib/mail/sh/check-permissions are now in the /usr/sbin directory. See Other Files Used for Mail Services. For backward compatibility, symbolic links point to each file's new location.
Table 14–9 Contents of the /etc/mail/cf Directory Used for Mail Services
Name |
Type |
Description |
File |
Describes the configuration files. |
Symbolic Link |
As of the Solaris 10 release, this file name is linked to cf/sendmail.cf. This file used to be the main configuration file. |
Symbolic Link |
As of the Solaris 10 release, this file name is linked to cf/sendmail.mc. This file was the file used to create the main configuration file. |
File |
Provides rules for building new configuration files. |
File |
Is the configuration file for the mail submission program (MSP), which is used to submit messages. |
File |
Is the file used to build the submit.cf file. The file defines m4 macros for the mail submission program (MSP). |
File |
Is the main configuration file for sendmail. |
File |
Contains the m4 macros that are used to generate the sendmail.cf file. |
Symbolic Link |
As of the Solaris 10 release, this file name is linked to cf/sendmail.cf. This file used to be the configuration file for hosts that NFS-mount /var/mail from another host. |
Symbolic Link |
As of the Solaris 10 release, this file name is linked to cf/sendmail.mc. This file used to contain the m4 macros that were used to generate the subsidiary.cf file. |
Directory |
Provides site-dependent subdomain descriptions. |
File |
Is the generic domain file from Berkeley Software Distribution. |
File |
Is the domain file with changes that make sendmail function like the previous Solaris versions of sendmail. However, relaying is disabled completely, sender addresses with no host name are rejected, and unresolvable domains are rejected. |
File |
Is the default domain file with changes that make sendmail function like the previous Solaris versions of sendmail. |
Directory |
Contains definitions of specific features for particular hosts. See README for a full description of the features. |
Directory |
Contains site-independent include files. |
Directory |
Contains definitions of mailers, which include local, smtp, and uucp. |
File |
Obsolete: as of the Solaris 10 release, this file name is renamed to cf/sendmail.mc. |
Directory |
Describes various operating system environments. |
File |
Defines default local mailer as mail.local. |
File |
File |
Defines local mailer as mail. |
File |
Defines local mailer as mail.local (in LMTP mode), enables IPv6, specifies /var/run as the directory for the sendmail.pid file. |
File |
