System Administration Guide: Network Services
How to Load the Socket Utility Library for NCA
Follow this process only if your web server does not provide native support of the AF_NCA socket.
In the startup script for the web server, add a line that causes the library to be preloaded. The line should resemble the following:
LD_PRELOAD=/usr/lib/ /usr/bin/httpd
