This chapter provides a list of the major topics covered in this book. In addition it includes a description of the PERL service that is included in this release.
The following services or utilities are covered in this book:
The Practical Extraction and Report Language (Perl) is a tool that can be used to generate scripts to assist with system administration tasks.
NCA provides improved web server performance by caching web pages.
NTP and time-related utilities can be used to synchronize time for many systems.
NFS is a protocol that provides the ability to access file systems from a remote host.
SLP is a dynamic service discovery protocol.
Mail services allow for a message to be sent to one or more people while routing the message over whatever networks are necessary.
PPP is a protocol that provides point-to-point links between remote hosts.
UUCP enables hosts to exchange files.
These commands are used to access files on remote systems. The commands include ftp, rlogin and rcp.
This Solaris release includes Practical Extraction and Report Language (Perl) 5.8.4, a powerful general-purpose programming language that is generally available as free software. Perl has emerged as the standard development tool for complex system administration task because of its excellent process, file, and text manipulation features.
Perl 5 includes a dynamically loadable module framework, which allows the addition of new capabilities for specific tasks. Many modules are freely available from the Comprehensive Perl Archive Network (CPAN) at http://www.cpan.org. If you wish to build and install add-on modules from CPAN using gcc, you can do so using the /usr/perl5/5.8.4/bin/perlgcc script. See the perlgcc(1) man page for details.
Several sources of information about Perl are included in this Solaris release. The same information is available by using these two mechanisms.
You can access the man pages by adding /usr/perl5/man to your MANPATH environment variable. This example displays the Perl overview.
% setenv MANPATH ${MANPATH}:/usr/perl5/man % man perl |
You can access additional documentation by using the perldoc utility. This example displays the same overview information.
% /usr/perl5/bin/perldoc perl |
The perl overview page lists of all the documentation that is included with the release.
In general, the 5.8.4 version of Perl is compatible with the previous version. Scripts do not have to be rebuilt or recompiled to function. However, any XSUB-based (.xs) modules require recompilation and reinstallation.
The Solaris version of Perl was compiled to include system malloc, 64-bit integer and large file support. In addition, appropriate patches have been applied. For a full list of all configuration information, review the results from this command.
% /usr/perl5/bin/perlbug -dv --- Flags: category= severity= --- Site configuration information for perl v5.8.4: . . |
You can generate a shorter list by using perl -V.
