System Administration Guide: Network Services
ProcedureHow to Configure a Machine on a Leased Line
  1. Become superuser on the local machine (router) or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Add an entry for the remote peer in the router's /etc/hosts file.
    # cat /etc/hosts
    # Internet host table
    127.0.0.1       localhost
    192.168.130.10  local2-peer        loghost
    192.168.130.11  local1-net
    10.0.0.25       farISP
    The example /etc/hosts file is for the local router at the fictitious LocalCorp. Note the IP address and host name for the remote peer farISP at the service provider.
  3. Create the file /etc/ppp/peers/peer-name to hold information about the provider's peer.
    For this example leased-line link, you create the file /etc/ppp/peers/farISP.
    # cat /etc/ppp/peers/farISP
    init '/etc/ppp/conf_hsi'
    local
    /dev/hihp1
    sync
    noauth
    192.168.130.10:10.0.0.25
    passive
    persist
    noccp
    nopcomp
    novj
    noaccomp
    The following table explains the options and parameters that are used in /etc/ppp/peers/farISP.
    Option
    Definition
    Starts the link. init then configures the HSI interface by using the parameters in the script /etc/ppp/conf_hsi.
    local
    Tells the pppd daemon not to change the state of the Data Terminal Ready (DTR) signal. Also tells pppd to ignore the Data Carrier Detect (DCD) input signal.
    /dev/hihp1
    Gives the device name of synchronous interface.
    sync
    Establishes synchronous encoding for the link.
    noauth
    Establishes that the local system does not need to demand authentication from the peer. However, the peer could still demand authentication.
    Defines the IP addresses of the local peer and the remote peer, separated by a colon.
    passive
    Tells the pppd daemon on the local machine to go quiet after issuing maximum number of LCP Configure-Requests and to wait for the peer to start.
    persist
    Tells the pppd daemon to try to restart the link after a connection ends.
    noccp, nopcomp, novj, noaccomp
    Disables the Compression Control Protocol (CCP), Protocol Field compression, Van Jacobson compression, and address and control field compression, respectively. These forms of compression accelerate transmissions on a dial-up link but could slow down a leased line.
  4. Create an initialization script that is called demand, which creates the PPP link as part of the booting process.
    # cat /etc/ppp/demand
    #!/bin/sh
    if [ -f /var/run/ppp-demand.pid ] &&
       /usr/bin/kill -s 0 `/bin/cat /var/run/ppp-demand.pid`
    then
    else
            /usr/bin/pppd call farISP
    fi
    The demand script contains the pppd command for establishing a leased-line link. The following table explains the content of $PPPDIR/demand.
    Code Sample
    Explanation
    if [ -f /var/run/ppp-demand.pid ] && /usr/bin/kill -s 0 `/bin/cat /var/run/ppp-demand.pid`
    These lines check to see if pppd is running. If pppd is running, it does not need to be started.
    This line launches pppd. pppd reads the options from /etc/ppp/options. The call farISP option on the command line causes it to read /etc/ppp/peers/farISP, also.
    The Solaris PPP 4.0 startup script /etc/rc2.d/S47pppd invokes the demand script as part of the Solaris booting process. The following lines in /etc/rc2.dS47pppd search for the presence of a file that is called $PPPDIR/demand.
        if [ -f $PPPDIR/demand ]; then
                    . $PPPDIR/demand
            fi
    If found, $PPPDIR/demand is executed. During the course of executing $PPPDIR/demand, the link is established.
    Note –
    To reach machines outside the local network, have users run telnet, ftp, rsh, or similar commands.
See Also
If you have followed all the procedures in this chapter, you have completed the configuration of the leased-line link. The following list provides references to related information.
