System Administration Guide: Network Services
Assigning IP Addresses by sppp Unit Number
If you are using either PAP or CHAP authentication, you can assign IP addresses to callers by the sppp unit number. The following shows an example of this usage.
myclient ISP-server mypassword
The plus sign (+) indicates that the unit number is added to the IP address. Note the following:
