pppd debug output contains Connect script
failed
Your chat script supplies a user name and password.
ogin: user-name
ssword: password
However, the peer that you intended to connect to does not prompt for
this information.
Delete the login and password from the chat script.
Try to call the peer again.
If you still get the message, call the ISP. Ask the ISP for
the correct login sequence.
The /usr/bin/chat -v log contains "expect
(login:)" alarm read timed out
ogin: pppuser
ssword: \q\U
However, the peer that you intend to connect to does not prompt for
this information.
pppd debug output contains possibly looped-back
The local machine or its peer is hanging at the command line and not
running PPP. An incorrectly configured login name and password are in the
chat script.
If you still get the message, call the ISP. Ask for the correct
login sequence.
pppd debug output
shows that LCP activates, but the link terminates soon afterward.
The password in the chat script might be incorrect.
Ensure that you have the correct password for the local machine.
Check the password in the chat script. Fix the password
if incorrect.
Text from the peer begins with a tilde (~).
ogin: pppuser
ssword: \q\U
this information.
If you still get the message, call the ISP. Request the correct
login sequence.
The modem hangs.
Your chat script contains the following line to force the local machine
to wait for the CONNECT message from the peer:
Use the following line when you want the chat script to wait for CONNECT
from the peer:
End the chat script with ~ \c.
pppd debug output contains LCP: timeout
sending Config-Requests
from the peer:
pppd debug output
contains Serial link is not 8-bit clean
from the peer:
pppd debug output contains Loopback
detected
from the peer:
pppd debug output contains SIGHUP
from the peer:
