System Administration Guide: Network Services
Before You Set Up the Dial-out Machine
Before you configure a dial-out machine, gather the information that is listed in the following table.
Note –
The planning information in this section does not include information to be gathered about authentication or PPPoE. For details about authentication planning, refer to Planning for Authentication on a Link. For PPPoE planning, refer to Planning for DSL Support Over a PPPoE Tunnel.
Table 16–2 Information for a Dial-out Machine
Information
Action
Maximum modem speed
Refer to documentation that was provided by the modem manufacturer.
Modem connection commands (AT commands)
Name to use for dial-in server at the other end of the link
Create any name that helps you identify the dial-in server.
Login sequence that was required by dial-in server
Contact the dial-in server's administrator or ISP documentation if dial-in server is at the ISP.
