System Administration Guide: Network Services
Using /etc/ppp/options.ttyname on a Dial-out Machine
For a dial-out system, you can create an /etc/ppp/options.ttyname file for the serial port that is connected to the modem, or choose not to use /etc/ppp/options.ttyname.
Note –
Solaris PPP 4.0 does not require an /etc/ppp/options.ttyname file to work correctly. A dial-out machine might have only one serial line for PPP. Furthermore, the dial-out machine might require few options. You can specify any required options in another configuration file or on the command line.
