System Administration Guide: Network Services
ProcedureHow to Modify the Master Map
  1. Log in as a user who has permissions to change the maps.
  2. Using the nistbladm command, make your changes to the master map.
    See the System Administration Guide: Naming and Directory Services (NIS+).
  3. For each client, become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  4. For each client, run the automount command to ensure that your changes become effective.
  5. Notify your users of the changes.
    Notification is required so that the users can also run the automount command as superuser on their own computers. Note that the automount command gathers information from the master map whenever it is run.
