System Administration Guide: Network Services
ProcedureHow to Access CD-ROM Applications With Autofs
Note –
Use this procedure if you are not using Volume Manager.
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Update the autofs map.
    Add an entry for the CD-ROM file system, which should resemble the following:
    hsfs     -fstype=hsfs,ro     :/dev/sr0
    The CD-ROM device that you intend to mount must appear as a name that follows the colon.
