System Administration Guide: Network Services
ProcedureHow to Consolidate Project-Related Files Under /ws
Assume that you are the administrator of a large software development project. You plan to make all project-related files available under a directory that is called /ws. This directory is to be common across all workstations at the site.
  1. Add an entry for the /ws directory to the site auto_master map, either NIS or NIS+.
    /ws     auto_ws     -nosuid
    The auto_ws map determines the contents of the /ws directory.
  2. Add the -nosuid option as a precaution.
    This option prevents users from running setuid programs that might exist in any workspaces.
  3. Add entries to the auto_ws map.
    The auto_ws map is organized so that each entry describes a subproject. Your first attempt yields a map that resembles the following:
    compiler   alpha:/export/ws/&
    windows    alpha:/export/ws/&
    files      bravo:/export/ws/&
    drivers    alpha:/export/ws/&
    man        bravo:/export/ws/&
    tools      delta:/export/ws/&
    The ampersand (&) at the end of each entry is an abbreviation for the entry key. For instance, the first entry is equivalent to the following:
    compiler		alpha:/export/ws/compiler
    This first attempt provides a map that appears simple, but the map is inadequate. The project organizer decides that the documentation in the man entry should be provided as a subdirectory under each subproject. Also, each subproject requires subdirectories to describe several versions of the software. You must assign each of these subdirectories to an entire disk partition on the server.
    Modify the entries in the map as follows:
    compiler \
        /vers1.0    alpha:/export/ws/&/vers1.0 \
        /vers2.0    bravo:/export/ws/&/vers2.0 \
        /man        bravo:/export/ws/&/man
    windows \
    files \
        /vers3.0    bravo:/export/ws/&/vers3.0 \
    drivers \
    tools \
        /           delta:/export/ws/&
    Although the map now appears to be much larger, the map still contains only the five entries. Each entry is larger because each entry contains multiple mounts. For instance, a reference to /ws/compiler requires three mounts for the vers1.0, vers2.0, and man directories. The backslash at the end of each line informs autofs that the entry is continued onto the next line. Effectively, the entry is one long line, though line breaks and some indenting have been used to make the entry more readable. The tools directory contains software development tools for all subprojects, so this directory is not subject to the same subdirectory structure. The tools directory continues to be a single mount.
    This arrangement provides the administrator with much flexibility. Software projects typically consume substantial amounts of disk space. Through the life of the project, you might be required to relocate and expand various disk partitions. If these changes are reflected in the auto_ws map, the users do not need to be notified, as the directory hierarchy under /ws is not changed.
    Because the servers alpha and bravo view the same autofs map, any users who log in to these computers can find the /ws namespace as expected. These users are provided with direct access to local files through loopback mounts instead of NFS mounts.
